idle problem
Old Sep 28, 2006 | 12:49 PM
JDM_199's Avatar
JDM_199
Default idle problem
well.....my idle is messed up. it idles like 1800-2000rpm and then it drops. one of my buddies told me that it could be a vaccum leak and to spray carb cleaner around the IM. and i did and nothing. i started spraying around the TB and i sprayed right at the TB Spring where the throttle cable hooks up at, and the idle drops. can anyone help me to fixing the problem? thanks
Old Sep 28, 2006 | 03:41 PM
JDM_199's Avatar
JDM_199
anyone know what could be the problem?
Old Sep 28, 2006 | 04:42 PM
Brar's Avatar
Brar
SEARCH
I fixed my idle problem by searching, you can too!
Old Sep 29, 2006 | 08:25 PM
JDM_199's Avatar
JDM_199
ok i searched. and all i found is that i should clean my fitv and iacv. and i did, better but still idles like crap.
Old Sep 29, 2006 | 08:45 PM
Brar's Avatar
Brar
https://www.honda-acura.net/forums/s...7&postcount=10
Old Sep 30, 2006 | 03:55 PM
94civicEX's Avatar
94civicEX
I got worms.
I just did this to my roommates GSR swapped civic......take off the fast idle valve...unscrew the plate...take a flat head and screw the white thing back down as far as you can....replace plate...replace fast idle valve...re-connect coolant lines...bleed.
99 Integra GSR
06 TSX
duck squad member #00003
