brake/caliper question
Old Sep 10, 2006 | 05:08 PM
mikey_e69's Avatar
mikey_e69
Default brake/caliper question
what is the parts called that the pads snap into in the rear??? it kinda surrounds the actual caliper and attaches with the two 14 mm bolts???
Old Sep 11, 2006 | 10:04 AM
m735is's Avatar
m735is
carrier
Old Sep 11, 2006 | 04:27 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Carrier/bracket, whatever.
Old Sep 12, 2006 | 01:42 PM
mikey_e69's Avatar
mikey_e69
anyone have a clue on where i could get one of those separate from the caliper???
Old Sep 12, 2006 | 02:03 PM
mikey_e69's Avatar
mikey_e69
also i just got some brembo blanks in the back. would it be better for me to go slotted or drilled for the front??? whats the diff between the two in performance?
Old Sep 12, 2006 | 04:37 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
you can probebly get one seperate from the caliper at either Acura or Autozone/Advance Auto. This is Sunnyside Acura, you can look for the part here.
https://www.acuraoemparts.com/delray...ll&ListAll=All
As for the rotors, slotted/drilled aren't really better if you're talking street use. They basically cool better and help transfer gases to the atmosphere easier than blanks. For street use you'll barely notice a difference.
Old Sep 16, 2006 | 04:59 AM
m735is's Avatar
m735is
Check junk yards for the carrier also.
Old Sep 16, 2006 | 08:26 AM
MTEng's Avatar
MTEng
Silly question, but what's wrong with the one on the car??? It's not exactly a wear item....
Slotted are a little easier on the pads... I use slotted and dimpled F & R .... for what that's worth.
Old Sep 16, 2006 | 08:28 AM
MTEng's Avatar
MTEng
How the $#@% do I delete a post
Old Sep 16, 2006 | 01:45 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Slotted rotors actually cut a new layer into the pads when they're applied heavily, how are they easy on them?
