turboing integra....radiator question
Old Sep 2, 2006 | 08:37 AM
LSBrother06's Avatar
LSBrother06
Default turboing integra....radiator question
hey i decided to try and bolt up the turbokit today and in doing so the way the manifold bolts up to the turbo it pushes the turbo forward and in the way of the radiator....so i decided to go with a del sol radiator but i dont no how to bolt up a del sol radiator to a integra frame...does anybody no where i can get directions on doing this or maybe even some suggestions...thank you
Old Sep 2, 2006 | 04:45 PM
2001TEGGSR's Avatar
2001TEGGSR
Should bolt right up on the one bracket, and you might have to drill a hole for the second one. Shouldnt be that hard, hold the rad. up to where you want to mount it and try to find a way. Have any pictures of where your having problems?
Old Sep 2, 2006 | 05:03 PM
FooD2000's Avatar
FooD2000
Still Water
yes 92-95 delsole halfcore radiator is the way to go, the inlet / outlet diameters should be the same. One side will fall in okay butt the otherside you need to improve. I used zip ties, they worked fine.
Old Sep 2, 2006 | 07:35 PM
LSBrother06
would a 1996 Del Sol SI work because i want a vtec one..becuase its thicker...but no i dont have any pictures..ill try and get some its dark outside now...
Old Sep 3, 2006 | 06:52 PM
FooD2000's Avatar
FooD2000
Still Water
Those ebay 92-95 del sole aluminum duel row radiaters will work.
Old Sep 5, 2006 | 11:45 AM
colby's Avatar
colby
i have a 92 integra with a b18c1 turbo and i am havin sone problems in need to hook up my v-tec and dont know how. im also having problems keeping it cool if any body can help me pleas do.
