Car won't start in the summer heat.
Old Aug 28, 2006 | 12:09 PM
jeems's Avatar
jeems
i be slow
Default Car won't start in the summer heat.
My friend's 93 Integra won't start a lot of the time during the summer or whenever its overly hot outside.
What could be the cause of this and/or how do you fix it?
Old Aug 28, 2006 | 01:20 PM
fastback's Avatar
fastback
Check the main fuel relay.
Old Aug 28, 2006 | 03:51 PM
tbcboo's Avatar
tbcboo
Ya the main fuel relay is probably the cause. My girlfriend just had that fixed like 2 weeks ago.
Our mechanic showed us a trick if it won't start: You know that little flat space on the side of your dash when the door opens? If it won't start bang on that a couple times with the side of your fist and it should start right up. Not a permanent solution, but in case you are stuck somewhere. He did that to my girlfriends car because it wouldn't start and he needed to move it; worked like a charm.
Old Aug 28, 2006 | 06:41 PM
beige2001ex's Avatar
beige2001ex
Does the motor turn and turn, but no go? Then after some time, especially when doors are open, it starts??
Old Aug 30, 2006 | 04:41 PM
Tobra's Avatar
Tobra
How old is your battery?
Old Sep 1, 2006 | 07:31 AM
bnuk's Avatar
bnuk
main relay x2.
listen for the fuel pump when you turn the key.
Old Sep 4, 2006 | 06:22 PM
ExpressFuelPumps.com's Avatar
HAN Approved Vendor
Battery is usually the first thing you should check. Everyone should have one of those rechargable boosters, I must have used mine literally over 100 times.
