where to find vac gauge line?
Old Aug 27, 2006 | 08:16 PM
mikey_e69's Avatar
mikey_e69
Default where to find vac gauge line?
ive been looking at auto parts stores and hardware stores and i havent yet found this tubing. its the stuff that comes with vac and boost gauges. i think its polyetheline or something. but anyways any info would be greatly appreciated!
Old Aug 27, 2006 | 08:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is nylon.
I wouldn't use it unless you have to. Try and see if some 1/8" rubber vacuum line will do the same thing.
Old Aug 28, 2006 | 02:04 PM
mikey_e69's Avatar
mikey_e69
well how do i connect that to the gauge??
Old Aug 28, 2006 | 02:08 PM
Provocateur
On permanent hiatus
Same way you would if it were nylon.
Old Aug 28, 2006 | 06:22 PM
mikey_e69's Avatar
mikey_e69
but can u find something that thin in rubber that will hold up or even that small period? the walls on the nylon are like 1/16" thick!!!
Old Aug 28, 2006 | 06:54 PM
Provocateur
On permanent hiatus
It is just air. It isn't like it is hot oil or anything.
Old Aug 30, 2006 | 03:30 PM
mikey_e69's Avatar
mikey_e69
one more quick question. whats the best line to tap into for vac gauge???
Old Aug 30, 2006 | 08:30 PM
Provocateur
On permanent hiatus
The easiest would be the FPR vacuum line. The best would be the brake booster, but you will have to figure out how to get a 1/2" hose down to 1/8".
