My 93 GSR needs a clutch any recomendations
Old Aug 24, 2006 | 05:43 PM
lugg_nuttz's Avatar
lugg_nuttz
Default My 93 GSR needs a clutch any recomendations
Bought the car used not sure when last clutch was installed but car now has 232,??? miles it feels like cable is sticking, I have to put it in N push pedal numerous times till I feel it release to change gears. I dont run the car much but do like to get on it from time to time what clutch should I go with?
Old Aug 24, 2006 | 09:15 PM
2001TEGGSR's Avatar
2001TEGGSR
ACT all the way!!! Stay away from any Mulit Staged or 3+ Puck Designs. There very high maintnence, and would be overkill without a built engine.
Old Aug 24, 2006 | 09:22 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
OEM replacement unless you need a stronger clutch for some reason.
Old Aug 25, 2006 | 08:53 AM
fastback's Avatar
fastback
The stock clutch sucks, I'd go aftermarket. ACT felt really nice to me in my friend's G3 and I liked the Centerforce I had in my 240.
Old Aug 25, 2006 | 01:50 PM
1.7na's Avatar
1.7na
I'm running a type R pressure plate and disk on my 93 GSR. Pedal effort is pretty much stock. Grabs a bit harder than the stock GSR disk/pressure plate setup. Works great for my daily driver with mods.
1.7na
Old Aug 25, 2006 | 06:03 PM
lugg_nuttz's Avatar
lugg_nuttz
Thanks all. I'm going with a OEM replacement. Its a sacks(spl)
Old Sep 1, 2006 | 08:38 PM
lugg_nuttz's Avatar
lugg_nuttz
Default New Clutch
OK got new clutch in I did have a grind going into 3rd before new clutch now it is going into 2nd no longer in 3rd whats the deal?
Old Sep 1, 2006 | 09:09 PM
Provocateur
On permanent hiatus
Is the clutch adjusted properly?
Otherwise, your tranny is on its way out.
Old Sep 1, 2006 | 10:24 PM
awormofearth's Avatar
awormofearth
sho nuff
the 93 GSR tranny's are well known for having weak synchros. 232,000 miles, i don't doubt that it'll need some rebuilding soon.
