Setting a clicking-type torque wrench
Old Sep 26, 2002 | 06:03 PM
g2tegls's Avatar
g2tegls
MR, ftw
Default Setting a clicking-type torque wrench
How do I do it? On the handle, there are two sets of numbers 0-9. On the shaft, there are marks for inch lbs going up 120, 240, etc up to 840. On the other side of shaft are lines to set m-kgs, I'm assuming that's what the other set of 0-9 on the handle are for. So a half revolution of the handle (10 units) sends it up one notch on the shaft (increments of 120 lb-inches). So I add 12 inch lbs for every notch on the handle that I turn? That makes the most sense but seems pretty weird.
Old Sep 26, 2002 | 06:48 PM
90'RS's Avatar
90'RS
On mine I pull on the bottom of the handle and turn the knob until the torque amount that I want is on the red line. Then I just torgue till it clicks and I repeat this a couple of time. For reference I have a craftsman but not sure exactly which one. I hope this helps.
Old Sep 26, 2002 | 07:46 PM
g2tegls's Avatar
g2tegls
MR, ftw
Well, here's a pic. It's not very clear.
Ben
Old Sep 27, 2002 | 08:31 PM
g2tegls's Avatar
g2tegls
MR, ftw
bump, muthafukka, bump, muthafukka, bump!
Old Sep 27, 2002 | 11:17 PM
b00gers's Avatar
b00gers
Ben
ok....find the lbs/inch numbers.
the handle where you turn has 0-9....thats the ones digits.
so to tighten to 85....keep turning till 80 gets to the handle, then turn till the 5 on the handle is at the arrow.
Old Sep 28, 2002 | 07:43 AM
gc94GSR's Avatar
gc94GSR
Roving Member
I believe that I have a similar torque wrench.
The markings between 0 and 9 are for setting a torque between the main markings on the handle (eg. adds that many in-lbs to the nearest handle marking).
On the bottom of the handle should be a lock nut.
Steps:
1) unscrew lock nut so that it is loose
2) lets say you want 125 in-lbs of torque
3) turn the handle until the 0 lines up with the centerline at the 120 in-lbs marking
(you are now set for 120 in-lbs)
4) turn the handle (to the right) until the 5 lines up with the line down the middle of the markings
(you should now be set for 125 in-lbs)
5) tighten the lock nut on the bottom of the handle
(you are now set for this amount of torque)
However, typically I would set the wrench at about half (say 60 in-lbs), tighten all the nuts and then reset the wrench to the desired setting (say 125 in-lbs) and then retorque all the nuts.
For lug nuts, you should try to torque them in a criss cross pattern.
Gordon.
Old Sep 28, 2002 | 09:35 AM
g2tegls's Avatar
g2tegls
MR, ftw
Steps:
Gordon.
That process would make sense. BUT: You say turn the "0" on the handle to line up with the "120" on the shaft. This is 120 inch lbs. Ok. Then turning the handle so "5" lines up with the centerline would make 125. Ok, maybe, but then as I keep turning when the handle gets to "0" again, it is lined up with "240" and NOT "130". That's why I was thinking that each notch on the handle is actually 12 inch pounds and not 1.
Old Sep 30, 2002 | 07:26 PM
gc94GSR's Avatar
gc94GSR
Roving Member
My 3/8 inch drive torque wrench has markings from 25 to 240 in-lbs in steps of 15 while my 1/2 inch drive torque wrench has markings from 25 to 250 ft-lbs in steps of 25 but I can change the setting by units of 1 on either wrench.
My theory is that your torque wrench is actually calibrated in ft-lbs (1 ft-lb = 12 in-lb) but marked in in-lbs so your actual range of adjustment is 120 to 840 in-lbs or 10 to 70 ft-lbs.
This makes sense since 120 to 240 in-lbs is 10 to 20 ft-lbs and that would make each marking 1 ft-lb.
If you really need in-lbs then I would recommend buying a new torque wrench with in-lb markings that will allow you to increment by a single in-lb.
Gordon.
