94 integra ls wont start...
Old Jul 28, 2006 | 01:13 PM
scooter_dmi's Avatar
scooter_dmi
Default 94 integra ls wont start...
ok so I have a 94 integra ls with 113k, and lately ive been having some trouble starting it up. i just bought it about a month ago, and things were fine for a while, but recently (about a week and a half ago) its not been starting up very well. all the electronics turn on, but when i turn the key itll try and start up, but its just not going. ive had the cap and rotor checked and those are fine, ive had the spark plugs replaced, ive had the fuel filter replaced, ive had the battery checked and thats fine, but its still not going. it does start up sometimes, but then sometimes it doesnt. not really sure what else to check, so if anyone has any advice please let me know asap, thank you all very much your help is greatly appreciated
Old Jul 28, 2006 | 04:04 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
have you had your main relay checked?
Old Jul 28, 2006 | 04:22 PM
BtTurboM3's Avatar
BtTurboM3
when you turn the key to start it.....is it turning over? or does nothing happen?
Old Jul 31, 2006 | 09:56 AM
heffmatt25's Avatar
heffmatt25
Sounds like what happened to my car awhile ago. I had to replace the ignition coil and then the fuel pump relay. (My integra would start up then die right away)
Old Jul 31, 2006 | 10:00 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Wouldn't hurt to have your alternator checked either, if its not working or semi-working you won't have the power to start it up sometimes......i recently had probs wit my accord and after trial error (and using a multi-meter) found out my car wouldn't start or turn over sometime was cuz i didn't have enough power to start it.....bought a new alternator and problem went away starts up like a charm
Old Jul 31, 2006 | 10:53 AM
micha177's Avatar
micha177
i had the same exact problem with a 96 ls. sometimes it would start and sometimes it wouldnt. i could drive for 2000 miles turn the car off and it wouldnt start up again.....ten minutes later it would. i replaced the starter and never had another problem. try that if you havnt already.
Old Aug 1, 2006 | 06:45 AM
scooter_dmi
yeah it does turns over
alright thanks for all the suggestions, ill get it all checked out, hopefully it works out well, we'll see how it goes, thanks everyone
Old Aug 4, 2006 | 10:52 AM
Joe's Avatar
Joe
well 5 minutes ago my car would not start, I know what the problem is, I need a new starter. Ive been needing a new starter for like 5 months now and still keep pushing it away because after a few clicks it usually starts but now it wont start and it's starting to make noise like wouwouwouwouwowuwowwouwou ( the usual sound you hear when you turn on your car but it just keeps going)
guess ill call the garage :hs:
Old Aug 5, 2006 | 12:57 PM
micha177's Avatar
micha177
its two bolts, its easy...you can do it and save yourself a lot of trouble...
