ls to vtec
Old Jul 27, 2006 | 07:01 PM
abw's Avatar
abw
Default ls to vtec
i have a a ls integra and i want to know do i have to change out all the wire to change to a vtec engine its a obd1. do i have to change nothing but the egine wires or all including the wires beyound the fire wall
Old Jul 27, 2006 | 08:57 PM
Topend's Avatar
Topend
scooted
Wouldn't you get an ecu + wire harness with a VTEC motor? I would assume you need a harness for the extra "things" that come with that kind of motor.
Old Jul 28, 2006 | 04:27 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
.... huh?
research "ls-vtec" it's been beat to death.
as best i could understand... you have an OBDII integra... and your wanting to vtecisize it.
your going to need a new ECU to match the engine... if the one you have is OBDI...then buy a conversion harness.
you will not have to change the engine harness whatsoever... but if your ECU has a knock sensor you need to have it bypassed.
that's about all i could understand of your questions
Old Jul 28, 2006 | 06:04 PM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
if you have a obd1 ls and the vtec head you are throwing in there is a obd1.. you need to just add wires to hook up the vtec.. http://www.allmotorhonda.com/techpag...ies-wiring.htm tells you the wire colors and pins for the ecu.. you will also need a p28 or obd1 p72 ecu depending on the head... or you can just run some type of engine management (ie: crome, hondata)
