brake problem
Old Jul 10, 2006 | 10:36 AM
flybye's Avatar
flybye
Default brake problem
I just changed my rotors and pads last night,now when I come to a full stop, I hear the brakes squeck. what can this be? any ideas?
Old Jul 10, 2006 | 10:48 AM
Gearhead7's Avatar
Gearhead7
Did you use the anti squeak goop they give you w/ your pads? Ussually the squeak is the pads vibrating or not making good contact w/ the rotors.
Old Jul 10, 2006 | 01:46 PM
sk8ps's Avatar
sk8ps
If they only squeak when braking don't worry about it. The noise will eventually go away (assuming you did not use anti-squeak). If you did use it and there making that noise, you may want to double check the install. If the pads didn't come with anti-squeel, and you absolutely can't stand the noise. Take a trip to your local auto store, it should be cheap. I used CNC "disc brake quiet" and havent had any issues.
Old Jul 11, 2006 | 08:53 PM
flybye's Avatar
flybye
thanks guys
