jus bouht 98 4dr tegra.........$1500.00
Old Jun 29, 2006 | 08:09 AM
acritegitithype's Avatar
acritegitithype
blk/blkV10M5
Default jus bouht 98 4dr tegra.........$1500.00
Sos, Go A Big Project,starting From Scratch, Any Advice.
Old Jun 29, 2006 | 08:11 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
damn only 1500? was it stripped? is it a 4dr gs-r
Old Jun 29, 2006 | 08:19 AM
acritegitithype
blk/blkV10M5
INTACT, OKAY, A/C BLOWS COLD BUT I THINK WATER pump IS ABOUT TO GO STARTED GETTING HOT, db7 engine,
Old Jun 29, 2006 | 08:24 AM
v6_accord_jerz
Stupid Power Ball
WOW intact? good steal man, how many miles on the engine?
You have a DB7 engine??? you gotta RWD aston martin engine in the teg lol?
VEHICLE SPECIFICATIONS AND DIMENTIONSMPG (City/Hwy)11/18Wheelbase102.0"Overall Length183.7"Vehicle Height49.6"Vehicle Width72.0"Cargo Capacity6 ft.Front Headroom-Front Legroom-Rear Legroom-Seating Capacity4Final Assembly LocationGB
STANDARD ENGINEEngineDOHC 6.0-Liter, 60-Degree V12, 48-Valve, DOHC, SEFI All-Alloy Front/Longitudinal Mounted With Horsepower Of 420@6000, Torque Of 400@5000, Lightweight Aluminum Alloy Cylinder Heads and Block, Engine Oil/Water Heat Exchanger, Ionized Gas Misfire DetectioCompression Ratio10.30Horsepower@RPM420 hp @6000rpmTorque Lbs. Per Ft400@ 5000Cylinder ConfigurationVeeValves per cylinder4Bore3.50Stroke3.13Engine Block MaterialAlloyBlock Head MaterialAlloyFuel Capacity21.70 gallonsFuel TypeUnleadedFuel Delivery NameSEFI
STANDARD TRANSMISSIONTransmission6-Speed Manual Transmission With OverdriveSpeeds6Curb Weight4134lbs.sClutch type-Linkage-Heavy dutyNoOverdriveYes
OPTIONAL ENGINENone
OPTIONAL TRANSMISSIONTransmission5-Speed Automatic Transmission With OverdriveSpeeds5Torque ConverterNoCurb Weight0lbs.sStandard Gross Vehicle Weight-Maximum Gross Vehicle Weight-Clutch type-Linkage-Heavy dutyNoOverdriveYesTransmissionTouchtronic Transmission SystemSpeeds-Torque ConverterNoCurb Weightlbs.sStandard Gross Vehicle Weight-Maximum Gross Vehicle Weight-Clutch type-Linkage-Heavy dutyNoOverdriveNo
Old Jun 29, 2006 | 08:32 AM
acritegitithype
blk/blkV10M5
STOCK 4 CLY,146k, he needed $, and I got 1,800k on my M5, JUS SOLD 05 COMP PACK M3, NEED DAILY DRIVER BUT THIS THING NEED SOME REAL WORK DONE, PAINT ENGINE EXHAUST, HE HAD IT SITTIN FOR FIVE YEARS , JUST STARTED EVERY NOW AND THAN AND DROVE, NEVER STARTED DONING ANYTHING TO IT. i WANT TO TAKE TO THE SHELL AND START FROM SCRATCH
Old Jun 29, 2006 | 08:47 AM
v6_accord_jerz
Stupid Power Ball
I see.....How much money your willing to spend, do you want to Boost? do you just want to rebuilt the car into good working operation? not sure what your intentions are
Not sure what you meant before by db7 engine....if you gotta stock 4cyl teg with about 146k you can do 2 things......engine swap or rebuild your current engine but since you seem like you want to start with a just a shell....i'd swap the engine for a b18c1 or similar and boost.....go crazy man lol
Old Jun 29, 2006 | 10:25 AM
ihighro11eri's Avatar
ihighro11eri
are you going to use it as your daily driver? what are your plans with it?
Old Jun 29, 2006 | 10:56 AM
R_Squared's Avatar
R_Squared
LEVEL UP
DB7 is the chassis code for the LS/GS/RS/SE 4 door Integras.
Old Jun 29, 2006 | 11:33 AM
DaGip's Avatar
DaGip
4N2Ner
Well at first try to fix all the shit that is broken, and then from there on go crazy with the outside if you prefer, also why dont you do an engine swap, might aswell get an H22, if you have the money.
Old Jun 29, 2006 | 11:52 AM
v6_accord_jerz
Stupid Power Ball
oh i see.....when he said DB7 engine i was like wtf lmao
