A/C Compressor not coming on...
Old Jun 21, 2006 | 12:09 PM
kento's Avatar
kento
Default A/C Compressor not coming on...
when i press the ac button, i don't hear the compressor coming on, and cold air doesn't come out of the vents... the belt on the compressor is fine, so i assume it's a fuse or a switch? any ideas? this is for a 1995 integra se.
Old Jun 21, 2006 | 08:48 PM
stemyluv69's Avatar
stemyluv69
if it doesn't come on at all (no clutch engaging) the first thing to try is filling your system with refridgerent and adding dye/oil then taking a black light around all your AC lines in about a week to find out of there is a leak.
Old Jun 22, 2006 | 08:25 AM
bnuk's Avatar
bnuk
does the light on th A/C button come on?
Old Jun 23, 2006 | 01:25 PM
kento's Avatar
kento
yeh, the AC light comes on... the compressor clutch doesn't engage. So if the coolant is too low pressure the clutch won't engage? is there anyway to make sure that it's not something else before i bother refilling the coolant?
Old Jun 25, 2006 | 02:40 AM
Kai's Avatar
Kai
Rotorphile.
A '95 car? It probably lost it's charge.
Old Jun 26, 2006 | 02:22 PM
kento's Avatar
kento
so how exactly do i go about refilling it?
Old Jun 26, 2006 | 04:52 PM
Kai's Avatar
Kai
Rotorphile.
Take it to an A/C shop if you want to do it right. If it has completely lost its charge, it will need to be vacuum discharged before recharging. The drier may also need to be replaced.
Old Jun 26, 2006 | 09:55 PM
95tegRS's Avatar
95tegRS
AC needs charging. same thing happened to me last year.
Old Jun 26, 2006 | 10:19 PM
toanhung's Avatar
toanhung
there leaking some where
