1989 Acura Integra LS
Old Jun 18, 2006 | 11:26 AM
ApeX's Avatar
ApeX
Default 1989 Acura Integra LS
I just recently got an Acura Integra for $400, the engine is at 200k miles and I
want to rebuild it, but before I do I would like to see what kind of engine I can
stuff into with, with out changing engine mounts or anything super complex or
requires welding
From what I know it has a 1.6 liter DOHC 16 valve 4 cyclinder, 5 speed manual
transmission (not sure if thats needed)
As a side note, does anyone have some blueprints for this car?
Old Jun 18, 2006 | 11:33 AM
g290ls's Avatar
g290ls
they call me tater salad
welcome to han, you could swap a b16a1 which is what is in crxs and it will swap right in to place
Old Jun 18, 2006 | 12:29 PM
ApeX's Avatar
ApeX
Thank you, but does that engine meet or
exceed my current engines profomance?
i just got it and dont really know anything about import engines
so any help is very appricated
As noted here its only available in japan and europe.
89-92 Vti B16A1 4G - EE 1595 10.2 : 1 158 @
7600 rpm 111 lb/ft @
7000 rpm Europe
90-91 Si R B16A1 4G - EF 1595 10.4 : 1 160 @
7000 rpm Japan
Old Jun 18, 2006 | 07:33 PM
jlicrx's Avatar
jlicrx
you cannot swap a B-series engine into the 89 Integra without buying a mount kit, shift linkage, etc. - the only engine which will swap right in without aftermarket mounts, etc. is the 88-89 JDM Integra DOHC ZC 130hp - basically the same engine as your D16A1 with just a little more power - bolts right in using your transmission, wiring, axles, etc. - that engine is kind of hard to find - it is not the same as the DOHC ZC that came in the 88-91 JDM Civic/CRX Si models, which will not bolt into your car - it is also not the same as the "browntop" DOHC ZC that came in the 1st gen JDM CRX Si and 3d gen JDM Civic Si - the "browntop" used a vacuum ignition timing advance distributor (like the 86-87 Integra D16A1) - the later distributors will not bolt onto the "browntop" ZC
