Weird Problem
Old Jun 5, 2006 | 04:22 PM
teevee247's Avatar
teevee247
Default Weird Problem
This problem started about 4 or 5 days ago... basically when driving, my car would start hesistating anytime that I got on the gas even slightly (it felt like bad plugs or plug wires). Then on the 2nd day, I noticed that my Tach. was fluctuating wildly anytime the car would hesitate... then on the 3rd day, i noticed that my speedometer would fluctuate in sync with the fluctuations of the tach. occasionally...
I replaced plugs, plug wires, dist. cap and rotor... before I go an buy a new Distributor, i'm wondering if anybody has any ideas on what the problem could be and what to check for... thanks...
Old Jun 5, 2006 | 05:07 PM
teg92's Avatar
teg92
WHAT OK YEAH!
try changing the fuel filter
Old Jun 7, 2006 | 05:30 PM
Shooting411's's Avatar
Shooting411's
aka Gorilla Unit 33
is this before the motor is warmed up? ive noticed this in my gsr also. almost as if the engine gargles at 2krpms and before 3k but wont let you go higher some times.
Old Jun 7, 2006 | 05:32 PM
Tassimau's Avatar
Tassimau
Banned
if you have an IACV - idle air control valve. Try cleaning that, its on back of intake man. Even if it aint that, id clean it anyway
Old Jun 7, 2006 | 05:40 PM
Nors's Avatar
Nors
倍力恋
IAC only operates when the throttle plate is closed. Other then that its just air rushing through, and you will not notice a difference if air is making it through or not due to the throttle plate being open.
Old Jun 8, 2006 | 07:56 AM
teevee247's Avatar
teevee247
Problem ended up being a faulty ground wire (valve cover to body), the wire going into the terminals was corroded pretty bad and not giving a good contact. Replaced it with some 8ga audio wire and gold terminals, works great now. This weekend i'll end up replacing all my grounds (was kind of cold and raining last night, lol).
