Is this ok?
Old Apr 15, 2006 | 12:05 PM
a_integra_87's Avatar
a_integra_87
Traction, WTF is that?
Default Is this ok?
Well I relocated my battery to the trunk of my car. I have a optima yellow top. All I really did was remove the OEM mount, made some brackets and welded it into the trunk. Then used all OEM hardware to bolt it down. It shouldnt go anywhere.
Anyway Im using 4 gauge wire the entire way, for power and ground. (I had 25ft of brand new 4 gauge in my room so i used it).
My question is, I have a 80amp Rockford Fosgate fuse I guess you want to call it that. Its the type that when it blows it just unhooks a tab and pops out. Can I use that inline of the + wire incase a short, or should I get something smaller?
Also I went to a few auto parts stores and tried to go to a speaker store but it was closed. I wanted to T off the 4 gauge wire, because how it is originally there is the + comming off the battery and goes to the starter, then there is also a wire that goes to the fuse box right off of the battery clamp. I couldnt get a T or anything and its going to be super hard to solder 4 gauge wire, so I took the wire directly from the battery and went to the starter post like OEM, then at the same location I put the end of the wire going to the fuse box at that point, then up to the fuse box.
If you can follow what im saying, this wont cause a issue with the fuse box will it? My car starts and runs perfect no slow cranking, no dim lights.
Old Apr 15, 2006 | 12:07 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Why did you move it to the trunk?
Old Apr 15, 2006 | 12:12 PM
a_integra_87
Just for the hell of it
Old Apr 15, 2006 | 12:36 PM
a_integra_87
Kinda like that
Old Apr 16, 2006 | 02:23 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
1) Buy an aftermarket, gas-tight battery box with a vent.
It's absolutely mandatory, both to properly restrain the battery and to vent the gases created by charging the battery via the alternator. Transplanted OEM hardware won't pass tech inspection. Furthermore, the concentration of hydrogen gas in your trunk will facilitate corrosion and could lead to disaster should the battery terminals be short circuited.
2) Your fuse needs to be inline between the battery and fuse box..
3) In order to replicate the OEM wiring harness, splice the two 4-gauge wires together at the battery terminal clamp. I did this when I relocated the battery on my GTi, just strip, braid and clamp.
Old Apr 17, 2006 | 07:18 AM
a_integra_87
alright, I called National Auto and they have boxes in so ill be stopping in there later.
Also for the fuse box do I need 4 gauge wire? I used about 15ft of the 4 gauge wire to run to the starter...if i remember correctly that was about $2.25 per ft .
