knock sensor
Old Mar 29, 2006 | 05:18 PM
gsr converters's Avatar
gsr converters
Default knock sensor
just wanted to know if my car would start up if a knock sensor was bad or not hooked up at all, im not planning on removing it if that is what you guys think, just wanted to know, thanks
Old Mar 29, 2006 | 05:40 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Is this with B18C*.. or an LS/VTEC conversion? h:
In either case, the car will start and run, but VTEC will not engage.
The B18C* ECUs will expect feedback from a knock sensor before opening the VTEC solenoid. I believe you'll also log a CEL in the process.
Old Mar 29, 2006 | 05:45 PM
gsr converters
its a b18c1, i took it for a drive and you could hear and feel the vtec kick in, the reason is because a few weeks ago i totaled my body and so i took the tranny and engine and put it into a civic, i took it for a test drive yesterday beacuse he said it was done, but he also said that the check engine light would come on because he hadnt installed the knock sensor yet, said he is doing it tomorrow. all and i also used the ecu from my gsr just so you know,
Old Mar 29, 2006 | 06:08 PM
TheOtherDave™
Apathy Kills
Hmm. If you're running your stock ECU, he must have grounded out the knock sensor lead. It's not the best solution IMO, for obvious reasons, but it'll work.
Old Mar 29, 2006 | 06:17 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That doesn't work. The knock sensor creates its own voltage, so you need something to mimic the voltage created by normal engine operation.
In this case, I have no idea because vtec shouldn't be engaging with a CEL code 23.
Old Mar 29, 2006 | 06:32 PM
TheOtherDave™
Apathy Kills
I defer to you; I'm VTEC-deprived after all. h:
Perhaps we're all being decieved...
Old Mar 29, 2006 | 06:43 PM
Provocateur
On permanent hiatus
True, true. :chuckles:
I did a little reading on the knock sensor a while back and was reinformed that the knock sensor cannot be grounded out. This thread explains all: http://www.honda-tech.com/zerothread?id=1181854
Old Mar 29, 2006 | 06:53 PM
gsr converters
what could happen if i didnt run a knock sensor or it didnt work properly, either way, if it is stilll throwing a light il take it to a shop so their machine can diagnostic for me
