Preping oil gauge, help
Old Mar 23, 2006 | 11:36 AM
rugsr's Avatar
rugsr
How do my taillights look
is that how its done?
i have only seen 1 tap in the fron tof the pan for the drain
Old Mar 23, 2006 | 12:48 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have three options.
1. Get a Greddy oil sandwhich adapter and don't mess with that tap thing.
2. Use the tap and then add a brass tee so that you can plug in two sensors into one hole.
3. Use the tap, but don't plug the stock oil pressure sensor back in and deal with the idiot light.
Old Mar 23, 2006 | 01:04 PM
rugsr's Avatar
rugsr
No. 3 no thanks
Is No. 2 safe? i heard teeing off is a bad idea but as long as you use teflon tape you should be good.
No. 1, id rather not buy them, since there like 40bux i think(ebay) but is it better then teeing? id rather spend more now then fix something later.
Old Mar 23, 2006 | 02:51 PM
Provocateur
On permanent hiatus
Originally Posted by rugsr
No. 3 no thanks
Teeing isn't a good idea since brass is pretty soft and has been known to snap off threads if under too much stress. I went from tees to the sandwich adapter and it has three ports for everything you are trying to plug in. It is also easier to work with than a mess of tees at the back of the block.
Old Mar 24, 2006 | 07:55 AM
rugsr's Avatar
rugsr
this is her right
http://cgi.ebay.com/ebaymotors/OIL-F...QQcmdZViewItem
ye ill prob do this then
Old Mar 24, 2006 | 08:39 AM
rugsr's Avatar
rugsr
doesnt golden eagle sell them? i loked and copuldnt find any
id rather buy golden then ebay
Old Mar 24, 2006 | 09:05 AM
Provocateur
On permanent hiatus
The Greddy ones are around $50 and the GE ones are around $80-90. I bought mine from kteller, but I wouldn't recommend buying from them.
Old Mar 24, 2006 | 09:23 AM
rugsr's Avatar
rugsr
EVER HEAR OF THESE GUYS
http://www.importparts.com/shop/prod...oducts_id=1641
Old Mar 24, 2006 | 09:55 AM
Provocateur
On permanent hiatus
The Greddy one is cheaper.
