Suspension ?
Old Feb 10, 2006 | 12:10 PM
pnthr30's Avatar
pnthr30
Default Suspension ?
I am looking for opinions and/or reviews of either:
Tein H Tech springs and Comptech Sport springs.
I currently have both, and don't know which one to put on. Either one would be paired with Neuspeed/Koni Yellows (SP3's).
Anyone have any suggestions?
Car is G3 Integra sedan........
Old Feb 10, 2006 | 12:13 PM
Spec R's Avatar
Spec R
what are your driving priorities? either way, the h-techs and comp. sports are mild drops with mild increases in spring rate. your choice of shock is #1 so basically anything you pair up with those koni's will be a good choice. i would lean toward's the comptech's though, because of their spring rates, which i cant remember right now. i just know that they arent as f/r biased as the teins.
DB Squad
Integra Forum Moderator
Old Feb 10, 2006 | 12:23 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Argh...tech in OT..not good gonna toss you to teg forum.
Old Feb 10, 2006 | 12:25 PM
pnthr30's Avatar
pnthr30
Thanks for the quicky reply. I should have put a little more info. in my description, sorry. Anyways, this is just a daily driver.........I am just looking for a little better handling (to make driving a bit more fun) and a better overall look for the car.
Here is a bit of info. on both so no one has to look it up.
Stock spring rates on the G3 teg are 212/117.
Tein High Tech spring:
Rate: Front- 296 Rear- 257
Drop: Front- 1.7" Rear- .9"
Progressive
Comptech Sport Springs
Rate: F-335 R-135-210
Drop: F-1.25 R-1.25
F-linear R- progressive (of course)
Old Feb 10, 2006 | 12:27 PM
pnthr30's Avatar
pnthr30
Sorry.......the reason I put it in OT is because there isn't a suspension forum.....and the reason that I didn't put it in the Teg forum is because I figured that there may be people with Civics, TL's, Accords, etc. who may have used these springs and could offer some opinions/suggestions.
If you want/need to move it, feel free. Sorry.
Old Feb 10, 2006 | 05:13 PM
Driverman5777's Avatar
Driverman5777
Do some research its been covered alot
Old Feb 11, 2006 | 12:30 AM
Spec R's Avatar
Spec R
Progressive
Drop: F-1.25 R-1.25
if thats the rates, i'd definitely go with the teins...
DB Squad
Old Mar 6, 2006 | 08:16 PM
Rpheez5sho's Avatar
Rpheez5sho
1990 Acura Integra LS
is there anyway i can find a picture of a rear suspension on the internet for this car or can u tell me what is the peice in the rear that connects and is almost like a bone and has bushings in it i think without it now my car squeaks
Old Mar 7, 2006 | 04:00 AM
bnuk's Avatar
bnuk
are the SP3 the standard "yellows" or are those the race ones that are shipped revalved?
Old Mar 7, 2006 | 05:31 AM
pnthr30's Avatar
pnthr30
The ones that I am talking about (SP3's) are the Neuspeed edition Koni Yellow's, which are valved exactlly like regular Yellows. The only difference is that they have a shorter drop and 5 step levels of height adjustment instead of the 3 on regular yellows.
Someone once described them to me as "The neuspeed/koni yellows are designed for lowered vehicles. the shaft is about an inch and half shorter then a normal koni. so you will not have to worry about blowing out a shock using more aggressive springs."
http://www.neuspeed.com/products/pro...port&p_id=1819
I believe the SPSS3's are the race ones.
