Removing Gaskets??
Old Feb 2, 2006 | 09:40 AM
rugsr's Avatar
rugsr
How do my taillights look
Default Removing Gaskets??
Trying To Remove My Tb And Im Gasket And Its Like They Are Glued On!
They Come Off In Little Pieces....if That. Is There A Really Easy Way To Do This Or Just Keep Dick'n Around With My Screw Driver And Paint Scraper?
Old Feb 2, 2006 | 09:54 AM
Patman015's Avatar
Patman015
Gold Member
Be careful what you're scraping with. I think the throttle body is aluminum. You should be scraping with something plastic, they make plastic razor blades. You don't want to end up scratching it too bad or else it will leak with the new gasket on.
They aren't glued on, they're just really thin almost like paper. If it hasnt been taken off before, itll stick due to the years of being squished so tightly.
Old Feb 2, 2006 | 09:59 AM
rugsr's Avatar
rugsr
Aaaaaah What The Balls!
I Dont Think I Ruined It, I Wasnt Scraping Hard So.......another Thing Is My Im Gasket Looks Wet For Some Reason. Cant Figure Out Why
Old Feb 2, 2006 | 10:03 AM
teg92's Avatar
teg92
WHAT OK YEAH!
get a gasket scraper it will work, or a razor
Old Feb 2, 2006 | 10:13 AM
rugsr's Avatar
rugsr
lol who would have thought lol thanks
Old Feb 7, 2006 | 08:43 AM
rugsr's Avatar
rugsr
WELL SO FAR I HALF MOST OF IT OFF. i was abou to buy the IM gasket($8), TB($2) gasket and Exhaust gasket($13) at pepboys and then remembered that ive heard of "performance" gaskets. is this true and if so which should i get. Also would it be a bad thing to use 2 gaskets to increase the length of the runners or is the difference so small its a waste? thanks
Old Feb 7, 2006 | 08:21 PM
rugsr's Avatar
rugsr
no one knows?
Old Feb 7, 2006 | 08:31 PM
rugsr's Avatar
rugsr
eres 2 different kind. Ive heard of Hondata, does it work and is it worth it now that i got my turbo and the IC
http://cgi.ebay.com/ebaymotors/Honda...QQcmdZViewItem
heres a ebay looking one
http://cgi.ebay.com/ebaymotors/94-01...QQcmdZViewItem
Old Feb 7, 2006 | 09:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It isn't worth the effort or money, IMO. You will need longer studs if you decide on one of those "performance" gaskets.
Old Feb 7, 2006 | 09:29 PM
rugsr's Avatar
rugsr
OEM then?
