ABS Code 1
Old Jan 30, 2006 | 07:40 AM
tmtran73's Avatar
tmtran73
Default ABS Code 1
Anyone, please help. On my 94 Teg LS, I just found out that it has CODE 1 which mean the ABS pump motor over-run. What is it mean? Is it fixable? or I have to replace the new pump motor? Thanks in advance.
Old Feb 8, 2006 | 09:11 PM
nemesis2's Avatar
nemesis2
[QUOTE=tmtran73]Anyone, please help. On my 94 Teg LS, I just found out that it has CODE 1 which mean the ABS pump motor over-run. What is it mean? Is it fixable? or I have to replace the new pump motor? Thanks in advance.[/QU
Just try resetting the abs system by removing your B2 fuse under your hood-(it's in a little rectangular black box opposite the battery)
Old Feb 26, 2006 | 02:40 PM
4IntegraSpeed's Avatar
4IntegraSpeed
Default code 1
code 1 could be the accumulator modulator. its what holds the hydraulic pressure. if after 120 seconds of the motor running it dont build up enough pressure it will shut down.
