Problems!?!?!
Old Jan 28, 2006 | 07:40 PM
FASTER's Avatar
FASTER
Default Problems!?!?!
My 01 gsr now has a check engine light on i beileve code number 15, is number 15 ignition output signal? Also now my car can not keep an idle it will start up then die, also it will not start all the time.! HELPh:
Old Jan 28, 2006 | 07:51 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
when was the last time you serviced your car or had someone do it for you... I could use a little more information sorry for the crappy response im on my phone
Old Jan 29, 2006 | 06:05 PM
FASTER's Avatar
FASTER
well heres reall whats happening. I can start the car and about once i pull out of my drive way at around 2500 3000 the check engine came on i knew if i drove it anyfurther it would have died. So i brought it back to the garage checked the distibutor cap and checked the wires and changed the plugs(plugs were bad)as i read in another article. now i start it up and it comes on with code 8 which is the TDC postion. WHAT is going on by the way all of this happened after driving n the rain at about 60 to 70 on the highway for 2 hours. My first light came almost when i made it home. thanks i could use some help.
Old Jan 30, 2006 | 02:06 PM
tegbooster's Avatar
tegbooster
timings off :dunno:
Old Jan 30, 2006 | 02:23 PM
mr.crx's Avatar
mr.crx
ya timing
