help w/ ordering parts using parts diagram
Old Jan 19, 2006 | 11:49 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default help w/ ordering parts using parts diagram
take a look at the parts diagram why is there in the item description two labels for # 8, #7. Btw i'm purchasing bushings cause i'm getting alot of creeking noise on all four wheels durings bumps, if anyone know what parts I should change, let me know.
Link
Old Jan 20, 2006 | 11:12 AM
m735is's Avatar
m735is
There must be some difference between the two, maybe specific to your vehicles trim level, the dealer SHOULD be able to tell you which is right for your car.
A suspension sqeak could be coming from any moving part so pin pointing it maybe diffacult. Have you tried to listen and watch stuff while someone bounces the car? Any parts recently replaced? Stock everything? Miles?
As far as the actual mounts, I've never replaced them on my car, just clean them up and repaint if needed (salty roads where I live). And when I did the rubber mounts, the first time I cranked them down and bent the sleeve that fits in the middle of them causing a squeak over bumps. After redoing it (with new sleeve), it was OK.
I'm not saying that is your problem though. I would check:
balljoints-upper and lower
all bushings
sway bar links
Old Jan 22, 2006 | 10:52 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
can you tell me which part is the sleeve?
Old Jan 23, 2006 | 10:29 AM
m735is's Avatar
m735is
#12 on the picture. It's just a metal collar, my first ones were corroded to the shock, the second ones I crushed (slightly).
