93 Integra Ignition problem?
Old Jan 11, 2006 | 01:32 PM
shadowfire's Avatar
shadowfire
Default 93 Integra Ignition problem?
I have a 93 Integra LS and it is giving me fits. It dies and then starts while it is in motion and then it won't start. When I go to check the ignition at the sparkplugs it starts. The wires are fairly new, it has a new rotor button, new distributor cap. Any ideas?
Old Jan 11, 2006 | 02:09 PM
teg92's Avatar
teg92
WHAT OK YEAH!
have you ever replace the coil pack inside the dizzy?
Old Jan 11, 2006 | 02:19 PM
1.7na's Avatar
1.7na
Like teg92 said, check coil and/or igniter first. Might be the main relay as well.
HTH
1.7na
Old Jan 11, 2006 | 05:15 PM
Black92GSR's Avatar
Black92GSR
It sound like your ignition harness is going.... I had the same problem.... if you see smoke near the steering wheel its that for sure...
Old Jan 11, 2006 | 09:23 PM
shadowfire's Avatar
shadowfire
I have replaced both the coil and ignitor in the past. When they went bad they failed completely. I checked the resistance for both the primary and secondary of the coil and they check out.
