Intake Manifold question
Old Jan 10, 2006 | 04:07 PM
teg92's Avatar
teg92
WHAT OK YEAH!
Default Intake Manifold question
I have a 91 Integra and im going to put a 97 LS motor in there, should i switch over Intake Manifolds or just keep the 97 on there? Will the 97 work good without anyproblems?
Old Jan 10, 2006 | 05:06 PM
rugsr's Avatar
rugsr
How do my taillights look
i guess, i mean it came with the 97 LS motor, why not. worse case you could just switch it. I.M. are easy enough to pop in and out
Old Jan 10, 2006 | 08:44 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
how are you gona do the wiring? the wiring and plugs will be different...an obd2 engine in an obo0 car..
Old Jan 11, 2006 | 06:02 AM
teg92's Avatar
teg92
WHAT OK YEAH!
im using all the OBD0 stuff, throttle body, IACV and any other sensors
Old Jan 12, 2006 | 08:34 AM
slowG2's Avatar
slowG2
i put a 96 bi8b in my 93 DA i used the b18b intake manni......but the map sensors are differnt.
if yours is the same than you should have a map sensor on the top of the tb and another on the back/top of the intake manni.
i rewirred the one for the tb, and removed and plugged the one on the back of the imf.
hth
also if your OBD0 than you might have to change the fitv to.
Old Jan 12, 2006 | 10:13 AM
teg92's Avatar
teg92
WHAT OK YEAH!
hth
theres only 1 map sensor, im using all my OBD0 stuff there will only be one senson on the OBD2 IM that i wont use air intake temp sensor. Im using my OBD0 throttle body, IACV. and any other sensors in the IM
Old Jan 12, 2006 | 03:56 PM
teg92's Avatar
teg92
WHAT OK YEAH!
anyone else know?
