Squealling now
Old Nov 19, 2005 | 08:49 AM
travis in wa's Avatar
travis in wa
Default Squealling now
I changed the timing belt, tensioner, and drive belts 200 miles ago. It started with a chirp at startup. Now, pretty consitantly it'll squeal between 1500 and 2500 RPM. Then it just stops.
It's the embarrassing, obnoxious squeal and quite loud.
The tension on the drive belts seems reasonable.
I just checked it cold and it only chirped at startup but revved okay.
Last night when hot, it squealed like a stuck pig.
What is the common bone headed thing I did wrong?
Old Nov 19, 2005 | 03:56 PM
FooD2000's Avatar
FooD2000
Still Water
You probably didn't tighten one of the belts enough, my belts did the same thing and i found my alternator belt was loose. it's kinda of a pain to go check but if you want that squeal to stop.....
No pain, no gain, unless it's ro-gain.
Old Nov 20, 2005 | 12:07 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i'd suggest being careful w/ that as well...my s/c belt started out as a lil squeek and then i lost all boost and i came to find out the damn thing snapped on me....
ps. it runs off the alternator
Old Nov 20, 2005 | 08:42 PM
travis in wa
Thanks for the posts.
I crawled underneath and took a closer look at the alternator belt...and tightened it a bit. No more squeal.
The car is right on track burning or losing 1/2 quart of oil over 200 miles at 32 miles per gallon.
Old Nov 21, 2005 | 06:05 AM
1995Civic's Avatar
1995Civic
I hate ricers
Im sorry.....what???
Old Nov 21, 2005 | 06:14 AM
killuminati's Avatar
killuminati
All through your body
The car is on track with needing a rebuild maybe.
Old Nov 21, 2005 | 06:27 AM
travis in wa
Oops, that was just a sidenote to follow up on a previous post. This car burns alot of oil.
