Datalogger Analysis
Old Oct 21, 2005 | 09:56 PM
rh77's Avatar
rh77
Default Datalogger Analysis
Hey all-
I recently bought a datalogger that plugs into the OBDII port and records a variety of conditions (speed, throttle position, engine load, O2 Sensor(s) voltage, fuel trim, intake air temp, etc.) -- it's the Davis "CarChip E/X".
It's fun to track these variables , but I'd like to put the device to good use other than just a toy. In these times of high fuel prices , fuel economy is definitely a priority.
Is there a way I can use this data to alter the vehicle to get better gas mileage. I average 80/20 highway/city and get about 27 mpg on the '98 LS Auto. There's all kinds of info out there on re-chipping for increased horsepower, but what about economy
I'm just not sure where to start. Any thoughts? Thanks...
RH77
Old Oct 21, 2005 | 09:57 PM
94civicEX's Avatar
94civicEX
I got worms.
On a stock vehicle? Keep the stock map.
99 Integra GSR
06 TSX
duck squad member #00003
Old Oct 21, 2005 | 10:12 PM
rh77's Avatar
rh77
The stock airbox has been replaced by a cold-air setup and K&N Filter. The question is, would an free-flow exhaust help?
RH77
Old Oct 22, 2005 | 01:01 AM
94civicEX's Avatar
94civicEX
I got worms.
RH77
Sure it would help. You don't need to mess with stock mapping though.
99 Integra GSR
06 TSX
Old Oct 23, 2005 | 11:17 AM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
80mpg highway?? heh are you constantly coasting down hills?
lol anyways, if you wanna run for slightly better fuel mileage, you might wanna get slightly better spark plugs/wires and distributor cap/rotor (make the spark a bit more efficient) and run some Chevron w/ Techron fuel system cleaner and/or Lucas Oil fuel system treatment/upper cylinder lubricant (only do one per fill-up, and read the directions for em...)...I did all that on my car and I'm noticing slightly better mileage after all was said and done.
if you want to go for an aftermarket exhaust so that you can help with fuel economy, make sure you keep the piping diameter not too big (like, 2.25" max) and get some quality exhaust components...you won't want an overly free-flowing exhaust that'll rob your low-end...
hope this helps some
--Brian
