type r compression
Old Oct 3, 2005 | 12:49 PM
mobbin707's Avatar
mobbin707
Default type r compression
does anyone know what the compression is supposed to be for a 98 usdm type r? Im getting 150 accross and i don't know if thats what its supposed to be?
Old Oct 3, 2005 | 01:31 PM
97civicEXVTEC's Avatar
97civicEXVTEC
check your owners manual
Old Oct 3, 2005 | 01:35 PM
mobbin707's Avatar
mobbin707
I don't have it. It's not my car.
Old Oct 3, 2005 | 01:39 PM
sherwood's Avatar
sherwood
I missed Sean
compression values can change... depending on the equipment used and the tech doing the job... if the tech says that they are low then they are low, but if he says that they seem average then you are fine because all of them are within the magical 5-10 range
Old Oct 13, 2005 | 04:18 PM
01-0177's Avatar
01-0177
rockstar!
it also really depends on the way the test is done and what equipment you are using...
It seems low. But like he said the more important thing is that they are all within 10-15 of each other.
I've seen numbers between 170-280. Mine was in the 220's.
Old Oct 19, 2005 | 11:44 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
i had 195 all across when i had mine tested a yr ago
Old Oct 19, 2005 | 11:58 AM
teg92's Avatar
teg92
WHAT OK YEAH!
150 seems kind of low heres a write up on it to see make sure your doing it right http://www.c-speedracing.com/howto/c...t/comptest.php
