instrument lights
Old Oct 2, 2005 | 04:57 PM
gsr92hatch's Avatar
gsr92hatch
Default instrument lights
i was driving down the road last night and i came across some road work. at the end of the road work there was a nice little bump that i didnt see, and i hit it. immediately after i hit the bump my instrument lights stopped working, and havent come on since. i checked the fuse and it seems to be fine, what other simple solutions would you suggest before spending money to get something small like this fixed when it could be easily done myself for much less??
i checked the owners manual for other solutions such as bulb locations and such, but all it says about the instrument panel is the fuse location
Old Oct 2, 2005 | 05:21 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
Did you check to see if the harness came loose? The bump might have been big enough to knock the connection loose and kill the lights.
Old Oct 2, 2005 | 08:28 PM
tgansert's Avatar
tgansert
is all good
Yeah, the only obvious solution would be to check all the harnesses. Of course there may be an elusive issue if your harnesses check out.
But first - if your harnesses all check out... Check em again :nod:
Old Oct 4, 2005 | 01:21 PM
gsr92hatch's Avatar
gsr92hatch
where would the harness be? are they accessable thru the fuse panel?
