b18b-LS what gas to use?
Old Aug 30, 2005 | 09:43 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Default b18b-LS what gas to use?
can i use 87, 89, or 93, which is the right kind for my engine?
Old Aug 30, 2005 | 09:44 PM
sherwood's Avatar
sherwood
I missed Sean
87 the ls doesnt merrit premium
Old Aug 30, 2005 | 10:45 PM
VTEC-Power's Avatar
VTEC-Power
Well in CA, the highest octane is 91 which sucks but that is what I use in my B16, which is the minimum requirments, but I wouldn't use the cheapest gas, atleast 89
Old Aug 30, 2005 | 10:47 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
An LS will not benefit from the higher octane. With gas prices being the way they are, the bare minimum is fine.
If you had a vtec motor, you must put premium in.
Old Aug 31, 2005 | 12:19 AM
beyondmp3's Avatar
beyondmp3
Damn. I've been putting chevron 91 in like it was free. Have I been wasting cash all this time?
Old Aug 31, 2005 | 12:38 AM
tah0e918's Avatar
tah0e918
Well it depends actually IMO anyway
Because 2 weeks ago in SF 91 was like 2.99 a gallon and 87 was 2.79, so calculate 20 cents times 9-10 gallons thats roughly a lil more than 2-3 bucks more and u get 91 octane
But if u like to hold on to ur wallet and dont need the 91 octane then 2-3 bucks are saved
Speaking of 91, i heard that since the B18b doesnt need it, putting 91 actually can hurt ur motor, i doubt its true, but my friend suggested otherwise...dunno
Old Aug 31, 2005 | 04:30 AM
teggyls's Avatar
teggyls
J-villan
if you have an ls with stock timing then you will not benefit with anything above 87(or whatever regular unleaded is in your area)
if you've advanced your timing, you should move up to 91 or so, or else youll start to knock
Old Aug 31, 2005 | 05:07 AM
jdmeg6hatchy
i
thanks. wow, $2.79 for 89oct. its like $2.39 in Va
Old Aug 31, 2005 | 05:15 AM
tgansert's Avatar
tgansert
is all good
Keep 89 in there. A higher octane can cause detonation in the cylinders under high duress which can be a detriment to the performance. However, in a VTEC motor, the octane level that just prevents knock is what you want. This can vary depending on your elevation from sea level and moisture in the air. Using too low an octane level can cause the knock sensor to prevent VTEC from enaging. Using too high an octane can cause said detonation (premature firing of the cylinder due to too high of compression).
Old Aug 31, 2005 | 01:44 PM
jdmeg6hatchy
i
gas just went up today, i spoke to soon. $2.99 for 89 octane
