clicking noise
Old Aug 23, 2005 | 01:18 PM
sherwood's Avatar
sherwood
I missed Sean
Default clicking noise
hey guys, i've heard this clicking noise come from my clutch pedal all day, it doesnt sound serious, at first i thought it was a loose pedal or somehting, well it turns out it's not.. could this be a sign of something serious (a loose cable or something?) or is it just normal for things to rub after a while and make that noise in a teg?
the clicking sounds like that of a muffled ibm clicky keyboard and happens through differnt clutch pedal positions
Old Aug 23, 2005 | 03:02 PM
dubcac's Avatar
dubcac
I
Does it happen in neutral? It sounds like a throwout bearing. Do you notice any chatter while engaging the clutch?
Old Aug 23, 2005 | 03:29 PM
sherwood's Avatar
sherwood
I missed Sean
it happens even when the car is off and in neutral.. it has to be some loose connection... but what?
Old Aug 23, 2005 | 08:25 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Mine makes that same noise occasionally. It is in the pedal assembly, so I doubt it has any affect on the clutch itself.
If it doesn't hinder performance (mine doesn't), just ignore it until it becomes a noticable problem.
Old Aug 23, 2005 | 08:26 PM
sherwood's Avatar
sherwood
I missed Sean
yeash, i just didnt want it to be a loose bolt or somthing and then have my clutch go out
Old Aug 23, 2005 | 08:59 PM
Provocateur
On permanent hiatus
You could always check the pedal assembly for any problems.
