failed emissions...can someone look at my numbers?
Old Aug 19, 2005 | 12:42 PM
loserpunkx182's Avatar
loserpunkx182
Default failed emissions...can someone look at my numbers?
i have a 92 integra with a 2000b18c1 swap with a p72obd1. dc header, intake, and exhaust are my only mods. new o2 sensor was put in this month, new spark plugs and wires and a new distributor.
CO -
limit - 1.10
test - 5.92
HC
limit - 275
test - 423
NO
limit - 3600
test 595
RPM
1724
dilution
18.6%
Old Aug 19, 2005 | 02:09 PM
dubcac's Avatar
dubcac
I
Testing high on HC and CO, but low on NOx means that you're probably running too rich, and not all of the air/fuel is being ignited by your ignition. Here's a nifty little chart: http://www.car-sound.com/04charts.asp
Old Aug 19, 2005 | 02:50 PM
loserpunkx182
yeah my narrowband's sayin it's running a bar rich but those things aren't that accurate...
thanks for the chart...what would i do about the air injection?
Old Aug 19, 2005 | 03:16 PM
dubcac's Avatar
dubcac
I
Make sure your air filter is clean, and then maybe advance your timing a degree or 2, but make sure it's within the factory spec of 16° +/- 2°.
Old Aug 19, 2005 | 04:57 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
replace thermostat..?
Old Aug 20, 2005 | 06:30 AM
loserpunkx182
ok here's what i've seen:
this is a 92 b18b...almost the same thing
and mine
as u can see..the breather filter is where the hose on the 92 b18 is and it goes back into the intake. that could be it?
Old Aug 20, 2005 | 09:37 AM
VTEC-Power's Avatar
VTEC-Power
do you have a JDM B18c1?
Old Aug 20, 2005 | 09:46 AM
sherwood's Avatar
sherwood
I missed Sean
there arent any c1's in japan, only c's
there are no numbers in japan
Old Aug 20, 2005 | 10:55 AM
loserpunkx182
usdm b18c1
