DIY header replacement help!
Old Aug 18, 2005 | 04:54 PM
jame5x's Avatar
jame5x
Default DIY header replacement help!
Ok guys..i have a 95 integra..and i think i need to replace my header and gasket. im thinking about doing it myself. my question is..will it be easy? all i gotta do is remove the radiator..and unbolt the stock header right?
HELP PLEASEEEEEE
TIA!
Old Aug 18, 2005 | 04:56 PM
VTEC-Power's Avatar
VTEC-Power
unbolt the stock header, put on the new one and connect the 02 sensor. If you have the tools it is a easy project.
Old Aug 18, 2005 | 05:18 PM
jame5x's Avatar
jame5x
so i dont need to remove the radiator?
Old Aug 18, 2005 | 05:28 PM
VPUPPY's Avatar
VPUPPY
maybe the fans but i don't think you need to removed the radiator. you might be able to wiggle it out. also, be careful with the bolts and studs, they tend to get stuck and are sometimes broken.
Old Aug 18, 2005 | 05:39 PM
VTEC-Power's Avatar
VTEC-Power
if you bought good headers then no you won't, also if you bought a 2 piece header set it is easier to install
Old Aug 18, 2005 | 05:48 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You'll be fine. Lube up the nuts w/wd-40 wipe em down and get a 12mm socket and go to work. Ypu won't need to take anything out there is plenty of room.
Old Aug 19, 2005 | 07:05 AM
jame5x's Avatar
jame5x
thanks guys! i'll will try it this weekend..i'll give yall an update when its finished
Old Aug 19, 2005 | 06:41 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Oh and don't forget to get some zipstrips to hold the springs closed that connect between the bolts of the manifold and the cat. There a bitch to put on if you don't have anything to keep them closed while you mate the nut and bolt.
