Oil pressure Switch Socket Size?
Old Aug 4, 2005 | 07:01 PM
B18C Turbo's Avatar
B18C Turbo
Default Oil pressure Switch Socket Size?
What size socket do you use on the oil pressure sending switch located on the back of the block? I thought someone said 23mm but wasn't sure?
Old Aug 4, 2005 | 09:07 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I said it was 23mm, but I retract that. It is a little larger as I purchased the 23mm socket and it still wasn't big enough, so I used a crescent wrench to get it off. It may be around 25mm or so. I would try the crescent wrench first since it is adjustable, but if it doesn't work, purchase the socket. Make sure it is a deep socket, BTW.
Old Aug 5, 2005 | 02:25 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Its a 24mm, and yes it needs to be a deep one.
Old Aug 5, 2005 | 06:04 AM
B18C Turbo's Avatar
B18C Turbo
24mm cool thabks alot!
