OMG problem occured today
Old Sep 4, 2002 | 10:06 AM
Meguel24's Avatar
Meguel24
Platinum Plus Member
Default OMG problem occured today
OK, yesterday driving back to home from work I was revving to 5K and then all of a sudden the car did a jerk (like bog feel) and the rpm did a slight drop and then continued up past 5k. This happened 3 times on the way home. Then today driving to work, I was coming along 4500 rpm and then the same thing happened but worse. Did the jerking until I let go of the throttle and the check engine light flickered on and off. Ok must have to do with fuel, right? Now let me give u some history. My car is in need of 120K service (new fuel filter is part of the service.) I added a chip to the ECU 2 months ago (no problems) and my ecu was just sitting on the passenger floor, not tied to the side, I did attached it back on on Sunday (could a wire or clip become lose?) Or I did change my fuel on Sunday. I have always used the same fuel for the last 8 yrs and on Sunday I used Union 76 the one WITHOUT MTBE. Could that be a cause? Being that my engine has adapted to the previous fuel? Any help much appreciated.
Old Sep 4, 2002 | 12:08 PM
JEFFOS69's Avatar
JEFFOS69
Check the ECU wires and the battery on the car - It could be a short or loose wire and the car is actually is shutting off but it starts itself up again because the car is moving - (its basically push starting itself) this happend to a friend of mine his car was jerking around when driving sometimes and we figued out one of the battery terminals was grounding itself out on the rear wall of the engine bay sutting the motor of for a brief moment.
Hope this helps.
Old Sep 4, 2002 | 03:35 PM
Meguel24's Avatar
Meguel24
I haven't check anythign yet, but i did check tha oil and oh ish, very low, i added 2 quarts.
Old Sep 4, 2002 | 03:49 PM
reno96teg's Avatar
did you let the car sit before you checked the oil? if you check your oil immediately after the engine has been running, your reading will be off.
Old Sep 4, 2002 | 04:51 PM
BBanks357's Avatar
BBanks357
The SAME thing happend to my gsr a couple nights ago, Bogged down @5k like 3 times & then i just drove under 5k home & the next day I checked my oil & it was VERY low, burnign oil real bad, But i changed my oil & used synthetic & It hasnt happend since, & U said u checked your oil & u were 2 quarts low, As was I, So im sure this is the problem.
Old Sep 5, 2002 | 09:07 AM
Meguel24's Avatar
Meguel24
Yeah exactly same symptoms. I'm doing a 120K service today. Thanks for the help. BTW why are we burning so much oil?
Epoch
May 21, 2006 02:57 AM
LT
Dec 16, 2005 02:19 PM
Polipinay
Jan 25, 2005 12:50 PM
Falkor
Jan 23, 2005 07:20 PM
xxjustimajinxx
Dec 20, 2003 10:08 AM
