Suspension Squeaks Bad
Old Jul 29, 2005 | 08:05 AM
UpStateGS's Avatar
UpStateGS
Default Suspension Squeaks Bad
My 97 Integra is dropped with H&R Sports & KBY AGX w/ a camber kit. About a month ago the front end started squeaking, then got progressively worse. When I come to a stop the whole front end sounds like a worn out mattress.
Yesterday I replaced the upper and lower shock bushings & bump stops (front and back) but the problem still exists.
Has anyone else had a similar problem or know what else I should check?
Old Jul 29, 2005 | 08:07 AM
Illegal B16's Avatar
Illegal B16
New Zealand
the bushing thats machine pressed in the upper control arm should be the culprit.
Old Jul 29, 2005 | 08:28 AM
UpStateGS's Avatar
UpStateGS
Thanks! I wonder if this is something I can solve with a lubricant or I need to replace them since I found out my rear lower control arm bushing is seized.
Old Jul 29, 2005 | 10:09 AM
teg92's Avatar
teg92
WHAT OK YEAH!
buy some lubricant and spray some on there
Old Jul 29, 2005 | 11:40 AM
Illegal B16
New Zealand
The spray wont work for the top for long I dont think.
Old Aug 29, 2005 | 07:56 PM
RYounk007's Avatar
RYounk007
What type of spray lubricant would you recommend?
Old Aug 30, 2005 | 06:36 AM
UpStateGS's Avatar
UpStateGS
I bought some white silicone spray. It worked for a few days and now squeaks again. It's either the upper control arm bushing or the camber kits. Something I'll tackle over the winter.
