General A/C Question
Old Jul 21, 2005 | 12:16 PM
brothalynchhung's Avatar
brothalynchhung
Default General A/C Question
in my integra on the right side fuse box under hood i have Heater blower relay Cooling Fan, MG. Clutch Relay and Condenser fan relay, Im assuming MG Clutch is the Compressor Clutch? and do you think all of those relays need to be there for the system to work correctly
Old Jul 21, 2005 | 12:29 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Yes. I do think that the relays rely on each other for the system to work right, but I'm no mechanic or electrician. So I say see what others say.
Old Jul 21, 2005 | 04:15 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
yes they rely on each other and everything else. if your thermostat kicks in and you have a bad relay for your cond. fan then you dont have the best cooling for your motor. then again if your compressor kicks in and your cond. fan is suppost to come on then you get extra heat. also look into your wiring diagrams for the ac. it is all pretty much connected.
Old Jul 21, 2005 | 05:19 PM
brothalynchhung
i dont have wiring diagrams for it... thats my problem
