wiper fluid motor problem
Old Jul 18, 2005 | 10:37 PM
Redblurr's Avatar
Redblurr
Più Allentato
Default wiper fluid motor problem
:thinking: Im having problems with my winshild wiper fluid motor. when i want the fluid to come out it doesnt. eventhough i hear the motor working no water is spraying. i have checked the fluid level and its full. fuse is ok. what can it be? by the way my car is a 91 rs 3 dr. Thanks in advance. :thinking:
Old Jul 20, 2005 | 01:49 PM
Josher's Avatar
Josher
Do you have the wiper fluid resevoir filled? Always best to check the basics first. You might have a clog in the tube somewhere? Does the fluid come out in the back?
Odds are that you either have a leak, a clog or possibly a dead motor. Post back with any other information that you have.
Old Jul 20, 2005 | 02:23 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
It sounds like the nozzles are clogged.
Take a straight pin and insert it into each of the brass nozzles of the windshield squirters. Then try again. If you still have problems, then there's probably a kink in the hose somewhere between the pump and squirter.
Old Jul 20, 2005 | 07:39 PM
foot's Avatar
foot
I have had the check valves sieze up before. If the nozzles arent clogged i.e. you can blow air through the hoses going to them, then try to blow forward through the check valve. The check valve is a ball/spring valve inline with the windshield washer tubes. Usually located right on the inside of the hood.
Old Jul 20, 2005 | 09:24 PM
Redblurr's Avatar
Redblurr
Più Allentato
The hose wasn't connected. Since they replaced the hood because it got crushed in an accident before i bought the car. I found out today when a huge puddle of blue water formed under the car when I was trying to find out what the hell was wrong . I popped the hood and yup the hose was not connected. It works fine now. Thanks for your help guys.
