Integra Problem
Old Jul 12, 2005 | 03:15 PM
integra_gsr911's Avatar
integra_gsr911
Default Integra Problem
hey guyz i got a problem wid ma gsr, the ac is not workin fuh some reason i replaced ma fuses n checked ma enigne buh i don understand wht happend , some one help..
Old Jul 12, 2005 | 03:22 PM
sherwood's Avatar
sherwood
I missed Sean
i checked my spellcheck n my dicinary and i don understand wht yer sayun
integra forum is that way VV
Old Jul 12, 2005 | 03:41 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Engrish is fun! :yay:
What exactly is the problem you're experiencing? Any odd noises? Is there a belt on the compresser? Please reply in legible English.
Old Jul 12, 2005 | 04:29 PM
integra_gsr911
My air conditioner and the heater does not work at all , nothing happens when i press it. Well i really don't know much about cars if you guys know, you can msg me about it.
Old Jul 12, 2005 | 04:34 PM
westcoaststyle
did you check the fuses both under the dash and in the engine bay near the battery? check the relays too (little boxes in the same place as the fuses in the engine bay). Also, check near your driver's side headlight to be sure that all of the electrical connectors are connected. There are 2 there that are a part of the A/C system (at leasat on the Civic). Did you also look to see if the belt is attached. The belt may have broken without you knowing it so the compressor isn't turning. Check these things out and let us know.
Old Jul 12, 2005 | 05:16 PM
R_Squared's Avatar
R_Squared
LEVEL UP
check your blower motor under the passenger side glovebox too. I have to bang on mine every once in a while cause it doesn't seem to want to run...
Old Jul 12, 2005 | 05:54 PM
integra_gsr911
Guys i know i really don't know much about gsr . Well this is my first car but i checked all the fuse . They were all ok but there is a wire dat's riped off and it's hanging down . i gota go bk to my dealer to check it up buh he might charge me that's the problem.
Old Jul 12, 2005 | 07:33 PM
westcoaststyle
right-click -> save target as
http://tech.hybridgarage.com/tech/ma...e%20manual.pdf
That wire could easily be the problem. Consider buying a Chilton's or Haynes manual as well - found at your local auto store.
It's really hard to help you if you don't know much about the car, short of doing a DIY for you. :happysad:
Old Jul 13, 2005 | 12:54 PM
Redblurr's Avatar
Redblurr
Pił Allentato
Default I have the same problem, this is what they told me to do.....
My ac doesnt work so i go to the pros and i tell them what is wrong and they told me that the system(R12), is a very complicated type of system and it would be better to replace the system with a new R134 system. the guy told me it would roughly cost 2-300 hundred bucks to do it.
Old Jul 13, 2005 | 07:22 PM
worm696's Avatar
worm696
you can get a retrofit kit for around $25 assuming thats all you need. BUT you could get into compressor replacement, reciever/drier replacement, orifice tube replacement, etc... you could end up spending around $1000 if things arent as they seem. Good Luck.
