External Coil
Old Jul 12, 2005 | 09:18 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default External Coil
I was just wondering if any of you guys have done an external coil conversion on your teg?
Pros and Cons please?!?! Thanks
Old Jul 12, 2005 | 09:29 AM
Oldschool's Avatar
Oldschool
Boondock Saint
Default Coil
I haven't yet done one on my current car, but I had the exact same engine in my hatchie which did have one...
The pros:
More effecient combustion of the fuel air mixture which will give you slightly better gas mileage, and a slight pick up in horse power (these things are multiplied with forced induction, porting & polishing of the head, bigger injectors, fuel mapping changes, etc...except for gas mileage)
The con:
The biggest con, to me, was the fact that you are dependant on the companies rep to ensure that you don't get stuck somewhere. I had my coil go out one night and ended up having to get my hatchie towed home...that night sucked.
Old Jul 12, 2005 | 09:44 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I've used the MSD blaster external coil on my C1 for about 3 or 4 years now. Never had a problem with it and it didn't really give me any more power. It made the powerband more efficient and smooth, imo.
The con that I found, is that you have to use a proprietary distributor cap and they're not available everywhere. I'd get 2 caps if you go with the kit.
jmo
Old Jul 12, 2005 | 12:36 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
i think the factory Honda ignition system is good enough for anything under 300 hp
upgrading will make a miniscule difference if any IMHO
