quick ??? auto 2 manual
Old Jul 11, 2005 | 06:27 AM
Redlinerz's Avatar
Redlinerz
Default quick ??? auto 2 manual
Hey was up... I juss came across a 91 LS teg for $500... only problem is its automatic... Now I have converted a crx from auto to manual before is it the same process with the teg? On the rex I had to change to drivers side hub for the axel to fit, drill some holes for the clutch cable, and shiftlinkage, and install pedals and run reverse lights. I am kinda hoping I dont have to change the hub on the teg... do I? and is there anything else I need? thanks
Old Jul 11, 2005 | 08:36 AM
Integral's Avatar
Integral
Nightmare Motorsports
Here ya go... this question has been asked to death ;p
5speed tranny ls,gs,gsr,
transmission linkage
transmission mounts
clutch
flywheel
5 speed pedals
pressure plate
manual ecu
shifter and shift boot
clutch slave cylinders
clutch reservoir
matching throttle cable for pedal set
hydraulic lines
itermediate shaft
upper transmission mounts
Old Jul 11, 2005 | 08:48 AM
Redlinerz's Avatar
Redlinerz
why hydraulic? isn't a cable tranny used in the 91?.. so the axels from the automatic will work?
Old Jul 11, 2005 | 01:37 PM
root's Avatar
root
any ideas how much all this would cost? i'd like to do this on GF's 95 SE...
Old Jul 11, 2005 | 03:56 PM
honura's Avatar
honura
Seni
you need a Cable tranny,you DO NOT NEED another ecu, you can use both the axels and Half shaft.goodluck
Old Jul 12, 2005 | 09:50 AM
Integral's Avatar
Integral
Honura - Can you use the stock ecu from an auto 97 as well?
Old Jul 12, 2005 | 11:42 AM
honura's Avatar
honura
Seni
Yes. the only diffrence between the auto and manule is that the auto tells the solinoids to switch gears and stuff other then that it;s the same.
