Coil overs / to raise vehicle
Ok Han enthusiasts,
Need to find a set of coil overs to raise vehicle --not lower as most of the advertised coil overs are. Help needed as I reconstructed rear end and now seems to be bottoming out at times. :bowdown: :wiggle: :wiggle: |
I don't think they make coilovers to specifically raise an integra.. You might be able to raise it a little above stove, but not by much..You could just get new stock springs if you are bottoming out under normal driving/weight load.
Well when you get coilovers from a company, they're not already set to be lowered. You have to manually lower it. So when you get them, you can actually raise them up so you could raise your car.
What Length are you springs? You could get some 8 inch in lenght springs, and crank your spring perch as high as you can go, and that should raise your vehical. Ground Control will do custome springs with there threaded perch kit.
If the car is bottoming out, then the dampers are probably in need of replacement.
Stiffer springs and worn-out shocks are a recipe for disaster. :eek3: |
2 Attachment(s)
i have a set of skunk2 coilovers that i am selling, check out the pics attached to this post, they are at the highest setting.
