F20b ECU
F20b ECU
Hello,
I have a 94 Acura integra with a f20b w/ h22 trans lsd and I want to know what is a good ecu that is stock that I can use for it, so that it would pass Delaware inspection. In Delaware since this vehicle is a 94 it just need a two speed test.
The DMV technician will place the RPM sensor on the vehicle’s hood prior to beginning phase one of the test. Phase two the DMV technician will request that you increase the engine speed to 2,500 rpm. DMV shall not test emissions at a higher engine speed. To guide you through this process, the DMV technician shall direct you to follow the guidelines on the computer monitor located outside the driver’s door. The monitor shows your engine speed and indicates when you are in the acceptable range. This test takes approximately 2.5 minutes to complete.
Thanks,
Dom
Thanks,
Dom
I don't see why a chipped ecu wouldn't pass as long as you have a cat installed and it's tuned correctly, however to answer your question you could probably run a stock p13 from a 94-95 prelude but you'd have to have egr knock sensor and vtec pressure sensor all wired up
GReekbro
Engine Swaps, Tech & Tuning
7
04-29-2003 07:05 PM
