Front Hub Repleacement
Old Jul 8, 2005 | 12:32 AM
ratn0007's Avatar
ratn0007
Default Front Hub Repleacement
Hey Guys,
I think I saw this posted somewhere but.....
I have a '98 LS and the Acura Dealer is saying that I need to replace the left wheel bearing. I figure it would be a easier job for me just to replace the whole hub instead. Exactly how hard of a job is it? The dealer wants $350 just to replace the bearing. I'm a mid-range mechanic but I don't have any air tools.
thanks for any help that is provided
Old Jul 8, 2005 | 06:11 AM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
By hub do you mean upper and lower control arms and all that stuff?
Old Jul 8, 2005 | 08:16 AM
IN VTEC's Avatar
IN VTEC
I've never tried myself to remove the wheel bearing since you probably need a press and there's a collar piece that gets left behind on the hub and it needs to be removed by pressing it off. I always just let the machine shop take care of it. $20 a side and I give them the knuckle and the new wheel bearing.
Old Jul 21, 2005 | 11:11 PM
ratn0007's Avatar
ratn0007
On a scale of 1 - 10, how difficult of a job would this be?
Old Jul 22, 2005 | 06:46 AM
IN VTEC's Avatar
IN VTEC
To simply pop the knuckle off of the upper and lower control arms....probably a 3 or 4. I can usually have both off the car in under an hour.
Driving the knuckles and wheel bearings to the machine shop - difficulty level of 1.
Old Jul 22, 2005 | 05:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I actually just replaced my wheel bearings last weekend. Getting the knuckles off is pretty easy as long as the ball joints cooperate and separate easily.
I went to get the bearings pressed out and the new ones pressed back in because there is no way you can do it without a press. It cost me $70 to get it done, but it was mainly because the shop was open on Saturday and I was their last client of the day.
The wheel bearings are quite expensive at $65 a piece, but I recommend you do both sides while you are at it.
Old Jul 22, 2005 | 05:32 PM
ratn0007's Avatar
ratn0007
What brand of bearings do you guys recommend? I talked to the dealer and they wanted about $90 (not sure if that was for 1 or 2). checked on Checker Auto parts and they have Beck/Arnley brand for about $55 and a BCA brand for about $75. Any recommendations? Did you guys need any special tools?
Old Jul 22, 2005 | 05:34 PM
Provocateur
On permanent hiatus
You can order them cheaper at www.acuraautomotiveparts.org.
I get a discount at the dealership, so they weren't quite that expensive, but I recommend OEM. Do it right the first time and pay the extra money for the trusted quality.
