92 Teg wont start, no spark
Old Jul 3, 2005 | 07:32 PM
Peeeezy's Avatar
Peeeezy
Default 92 Teg wont start, no spark
Last week I got in my car to go home from work, My car wouldn't start. I got it towed home. My engine has no spark whatsoever. I have tried brand new ignition modules, and ignition coils and there is still no spark. All of my fuses check out fine. Only thing i know to do know is to buy a new dizzy, but the ignition coil and modules are fine....I am puzzled any help would be appreciated.
Old Jul 3, 2005 | 08:45 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
yeah a new distibutor sounds like the next thing if you've done the spark plugs, wires, and cap already
Old Jul 3, 2005 | 08:56 PM
dubcac's Avatar
dubcac
I
Does the distributor get power? Replacing it won't do much if you've already replaced the coil and ICM. If you haven't done so, try cap/rotor/plugs/wires. Is your CEL on? Try cranking the car for 20-30 seconds. If the car won't start, you have to crank it for a while in order for the CEL to come on.
Old Jul 4, 2005 | 08:42 AM
Peeeezy's Avatar
Peeeezy
The distributor is putting out no spark at all. I stuck a screwdriver in one of the spark plug wires and there was nothing. So i know it's not the plugs or wires and the rotory button is fine. I guess i'll try a new cap. yeah the cel is on but doesn't it stay on until the car is started.
Old Jul 4, 2005 | 09:20 AM
dubcac's Avatar
dubcac
I
Check the CEL code. If you dont know how to check the code, here's some info:
How to check: http://www.c-speedracing.com/faq/06.php
Code listing: http://www.c-speedracing.com/faq/05.php
When I asked if the distributor gets power, I didn't mean if it was producing spark. I was wondering if you are getting battery voltage to the distributor.
Old Jul 4, 2005 | 09:24 AM
FA9S8U's Avatar
FA9S8U
Be sure to check your fuses there should be a fuse to the igniton coil, if thats good, check and be sure that the intake cam is moving.
edit: check to be sure that your intake cam is moving.
Last edited by FA9S8U; Jul 4, 2005 at 09:25 AM. Reason: uhh ok you checked your fuses
Old Jul 4, 2005 | 10:00 AM
dubcac's Avatar
dubcac
I
Yeah, definitely check and make sure the cams spin when you try and crank it. No spark could be the cause of a broken timing belt.
Old Jul 4, 2005 | 12:27 PM
Peeeezy's Avatar
Peeeezy
The cams turn because to remove the rotory button I had to bump the ignition over so I could could get to the rotor screw. Where is the coil fuse located?
Old Jul 4, 2005 | 12:54 PM
foot's Avatar
foot
I would check the power source to the coil/ignitor. If there is power to the ignitor but it isnt switching and the ignitor/coil is good you may need a new pcm. hard to diagnose over the internet.
