$888 to fix my A/C
Old Jun 20, 2005 | 10:05 AM
SVT Russ's Avatar
SVT Russ
Las Vegas SEMA 2005:
Default $888 to fix my A/C
New compressor, compressor clutch, expansion valve, accumulator, 134a conversion, belt, labor to clean shavings from system when old compressor offed itself...
$888 :cry:
Old Jun 20, 2005 | 10:12 AM
teg92's Avatar
teg92
WHAT OK YEAH!
damn thats alot of $$ just to fix the AC
Old Jun 20, 2005 | 10:24 AM
BONE's Avatar
BONE
Thats a lot of money for an a/c fix but now you can be again lol
Old Jun 20, 2005 | 11:09 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would just remove it and drive with the windows open for that much in repairs. But that is just me. h:
Old Jun 20, 2005 | 11:30 AM
SVT Russ's Avatar
SVT Russ
So sad...the Teg's my daily ride, so AC is important...so I paid the bux to have the repairs done.
Car has only 68k miles on it...I think the AC failed cause it was rarely used.
Old Jun 20, 2005 | 11:32 AM
R_Squared's Avatar
R_Squared
LEVEL UP
not worth it...at least not to me, but on most of the cars I've owned the A/C never worked anyway. mine's not working either right now but that's just because all the refrigerant escaped when my short ram rubbed a hole into one of the high-pressure A/C lines. :shocked:
Old Jun 20, 2005 | 04:46 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
I hate my a/c. It lags my car so much. If you really wanted a/c you should have tried to fix it or replace it yourself.
Old Jun 20, 2005 | 06:42 PM
SVT Russ's Avatar
SVT Russ
So I should have tried to fix it myself, LOL!
Actually, I did try...but once I determined it was a bad compressor, it became a bigger job than I or most home mechanics can handle. Sure you can always replace a compressor, but removing all the components to clean out the metal shavings...including the evaporator in the dash...is a big PIA. If you don't clean the system, you risk screwing up the new $350 compressor. And sadly a typical home mechanic won't have the machine to properly flush and evacuate the A/C system before a fresh charge of freon goes in. Let's don't forget the necessity to convert the system to R-134a, since 12 isn't hardly available anymore in CA.
It pretty much sux when the compressor goes south.
Old Jun 20, 2005 | 08:17 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
...Good thing my a/c still works and I haven't tried to replace it...
Old Jun 20, 2005 | 08:53 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
thats me too :chuckles:
