vtec dependent headlight
well when i got my teg, both high beams and the right side low beam worked, but the left side low beam did not. A few weeks ago, while accelerating enthusistically from a stop sign, the left side low kicked on. I found this interesting. Ever since then, the left side low will kick on after a little run up to about 7 grand and then it will stay on as long as the car is on. I have no idea why the heck it is doing that and my passengers sometimes get irritated with the (necessary) vigorous acceleration so something needs to happen here. My only thought was that i might have some sort of bad voltage regulator and the extra juice from 7000 rpms is enough to kick it on. hmm. :( thoughts?
Sounds like a bad alternator to me. Notice any whining from the engine?
sounds like some jerry wiring to me, look it over and re-wire it correctly.
Bad ground maybe?
I would first replace the bulb and then if that doesn't work check the wiring. I'm guess its an old bulb though and that's the culprit.
Originally Posted by Tobra
Bad ground maybe?
Originally Posted by Illegal B16
This is wrong. Their is a wiring issue somewhere that has to do with you light specifically. Was any work done to the wiring of the car at all. Fog lights or guages...ect?
have you swapped the bulb with the one on the passenger side? check the harness see if its loose? if its not, then take a digital multimeter and a wiring diagram and back track the wiring from the headlight checking for neccessary ground and voltages(given in the wiring diagram).
