Compression Test #'s to CR?
Old Aug 31, 2002 | 01:20 PM
ShootingStar's Avatar
ShootingStar
Default Compression Test #'s to CR?
I just bought a compression tester and got these numbers:
#1 270
#2 265
#3 270
#4 272
This was with a warm engine, WOT & fuel pump disabled. When I bought the car I was told that the CR was 11.1:1 but have had no way to verify it. The motor has about 24k miles since build and is a B18C1 bottom end from a '96 GS-R with B16A pistons & new OEM rings, a B16A head with CTR cams, Portflow inner & ITR outer springs, OEM head gasket. The question is: Can the ACTUAL compression ratio be calculated from these compression numbers? Anybody got a GUESS?
Old Aug 31, 2002 | 02:45 PM
qtiger's Avatar
qtiger
Those rumbers seem a little higher than 11:1.
With the b18c1 bottom, b16 pistons, and b16 head, you should have a compression ratio of 11.42:1.
Old Aug 31, 2002 | 03:21 PM
Kevin's Avatar
Kevin
Banned
those are some really high numbers...
i do not know how to calculate the compression ratio....but also interested to learn...
Old Aug 31, 2002 | 03:47 PM
ShootingStar
Here's a link to a CR calculator http://www.c-speedracing.com/howto/c.../compcalc.html but I'm interested in what these compression numbers equate to as an ACTUAL CR.
R_Squared
4
Dec 28, 2005 05:14 PM
