A/C Died...Help Needed!
Old Jun 4, 2005 | 04:12 PM
SVT Russ's Avatar
SVT Russ
Las Vegas SEMA 2005:
Default A/C Died...Help Needed!
On my '91, the A/C compressor made a whistling/whirring noise for about 5 seconds and then stopped working. It makes a stinky smell when you try to run it.
Relay works (fan turns on). Compressor pulley spins/belt is okay.
I'm thinking it's the a/c clutch, or the compressor, or both.
Any thoughts here?
Thanks, Russ
Old Jun 4, 2005 | 06:23 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
a/c comp. clutch relay.
hot wire from your bat. to your comp.
if it works it is your relay or switch
Old Jun 5, 2005 | 05:06 AM
Carfan1's Avatar
Carfan1
Sounds like you fried the compressor clutch. Is the clutch still engaging on the compressor when you have the car running and the a/c on? If it isn't or if it slips just replace the compressor.
Old Jun 5, 2005 | 08:25 AM
SVT Russ's Avatar
SVT Russ
That's what I'm thinking...the smell must be from slippage of the a/c clutch. There's still freon in the system, so I think the compressor itself is ok.
The compressor is around $300, so the clutch has to be cheaper (I hope).
Old Jun 5, 2005 | 11:25 AM
musicfrisk's Avatar
musicfrisk
Default hey
there is another tension pulley in that loop, the bearings in mine froze a few years ago, the a/c stopped working and I got a similar smell - I would double check that pulley before investing in a new compressor
