how to install a electrical oil pressure gauge?
Old May 29, 2005 | 04:18 PM
abw's Avatar
abw
Default how to install a electrical oil pressure gauge?
how do u install a electrical oil pressure in a 94 integra without makeing the oil light come ?
Old May 29, 2005 | 04:43 PM
Kai's Avatar
Kai
Rotorphile.
The easiest way would be to install an oil filter spacer with pre-drilled and tapped 1/8th NPT ports. Install the sender in one of the ports and plug the others.
94civicEX's Avatar
94civicEX
I got worms.
Run a brass T fitting off the back of your block, one to the stock sensor, the other to your guage.
99 Integra GSR
06 TSX
duck squad member #00003
Old May 29, 2005 | 04:45 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Get a 14" or 15" long steel braided line that has male fittings on each side with the same threads as the OEM oil pressure sending unit. You can usually have it made at a fittings shop. Also get a T fitting that has all female fittings. Screw the line into the place where the OEM sending unit connects to the block. Screw the T fitting onto the other end of your steel braided line. Connect your OEM pressure sending unit to one opening on the T and the aftermarket gauge sending unit to the other opening on the T. Make a loop in the line to allow for the vibration of the engine to be diffused by the loop and mount the T and sending units to the firewall. Run your wires and you're all done.
Old May 29, 2005 | 07:04 PM
abw's Avatar
abw
do u have any pic of what u just said that would be nice and thank u for ur advise too.
