Rad fan not comming on
Well for the past couple weeks...well months actually my car has run past the 1/2 mark, but never over heated yet. Well today after about 1/2 hr drive i popped the hood and rad fans are not on. Drove the other 10min and checked again. Still dont work. Put the AC on and both fans come on.
ECT sensor? |
There is a coolant temperature switch that controls the radiator fan operation when the AC is turned off. Since the fan came on when you activated the AC, it is very likely that the coolant temp switch is dead.
Can you please tell me where this is located? Need to be replaced totally? I have to go to the dealer to get the stabilizer end links, so i might as well pick this up while im at it.
Does this mean that if my fans don't ever come on, it is unlikely that buying a new switch will solve my problem? Also, how do I test to see if the fans themselves still work? Thanks. |
well i think you said that when you turn the A/C on they both come on so i would think it was working. Also what if you have the reverse problem my fan doesn't turn off. I can park the car for a half an hour come out side and still hear the fans on. My mechanic said its a honda glitch as long as your battery is ok i'm fine is this true.
